My New Project - 64' CB77
Dexst
Post by Dexst » Wed May 06, 2009 6:15 pm
Im new to this fourm, but I just resently picked up this 1964 honda CB77 SH.
Im a Motorcycle apprentice, but on Harleys, and mainly bought this to learn on(metic), and I have a huge love for Cafes.
Where should I start?
Any suggestions would be fantasic!
Oh, I had a question, Can this bike start/ run w/out a battery installed?
Cheers
Dex
Post by davomoto » Wed May 06, 2009 8:16 pm
Dex, nice start! You'll need a battery to run her, one with a good charge, or you'll cook the rectifier. One thing that stands out to me is the tailight and bracket are not correct. looks like it's from a 70s SL Honda. Start by changing oil, flushing fuel tank, and petcock, cleaning carbs, check air filters, clean and adjust points, set timing, new plugs etc.
Dexst
Post by Dexst » Wed May 06, 2009 9:15 pm
Thanks! for 500 bucks I can go wrong!
good eye for spoting that taillight! kinda ugly!
what kind of battery should I drop in it?
12V ??AMP??
I have a scooter battery kicking around the shop...Will that work?
Does it have a eletric start? or am im going to be kicking it? (I have zero exp. with metric bikes)
Dexst
Post by Dexst » Wed May 06, 2009 9:24 pm
Post by davomoto » Thu May 07, 2009 2:10 pm
12V 9AH, if not mistaken. It does have electric start, the button is on the right bar switch. The scooter battery would probably be fine to start it on. If you have a Batterys Plus by you, they can get you the correct battery for about $40.
Dexst
Post by Dexst » Thu May 07, 2009 8:03 pm
Awsome!
I love this thing!
The throttle is stuck or very firm, what is the problem?
Thanks
Loudo
stuck throttle
Post by Loudo » Fri May 08, 2009 2:07 pm
I'm guessing your throttle slides are stuck in the carb barrels due to the varnish left behind when the gas dried out. I suggest you take off the tank and get to work. Unscrew the carb tops and squirt in some solvent, let it soak and then gently jiggle the throttle cables until the slides unstick.
I mean, for starters.
