CB 77 Drive Chain
Butch_2004
CB 77 Drive Chain
Post by Butch_2004 » Fri Oct 09, 2009 8:00 am
Am restoring 1964 CB77 and am in need of a chain for the bike.I believe it has a 34 tooth sprocket for the rear hub.Can anyone tell me What size chain and how many link I need for this bike? Thanks Butch
jensen
Post by jensen » Fri Oct 09, 2009 9:58 am
Hi Butch,
For the CB72, it's 34 tooth, since you have a CB77 it should be 30 tooth, so front 15 tooth, rear 30 tooth is standard for CB77. Chain is 530, 94 links if standard.
Butch_2004
CB77 Drive Chain
Post by Butch_2004 » Fri Oct 09, 2009 10:49 am
Do you know where I can acquire a chain for this bike?
mike69
chain
Post by mike69 » Fri Oct 09, 2009 11:27 am
I purchased one from my local Honda dealer and another one from my local motorcycle
repair/parts shop.
I think J.C.whitney sells them too.
66 Dream
78 Goldwing
Butch_2004
Oil filter on CB 77
Post by Butch_2004 » Fri Oct 09, 2009 11:31 am
What is the proper procedure on maintenance of oil filter on CB 77? Just remove and clean?
Gunner_CAF
Re: Oil filter on CB 77
Post by Gunner_CAF » Fri Oct 09, 2009 7:43 pm
Butch_2004 wrote:What is the proper procedure on maintenance of oil filter on CB 77? Just remove and clean?
Yes, Make sure you get the thrust bearing in the right location when you put it back together. You will find several posts here about this.
Gunner
Post by davomoto » Sat Oct 10, 2009 10:20 am
Check ebay, type in " 530 chain". Basically, the more you spend, the higher quality cahin you will get. I'd personally avoid an o-ring chain, as the are heavier, and rob power. You can get a chain in the correct length, or if you're not sure of your gearing, but one a few links longer, and cut to correct size.
