Shifter slop on grease fitting bolt
Dana01
Post by Dana01 » Sat May 21, 2011 4:16 pm
66 CB77:
Fred and others say that a good fix is to get a machined bushing to take up the wear of the grease-fitting bolt ("step arm fixing bolt"). Mine is sloppy as all getout.
While in neutral, the shifter end can move 20mm radially and 8 mm perpendicular to the bolt. Grease oozes out because there's so much slop.
Has anyone come up with a fix other than replacing both parts? I'll ask Nick at Ohio Monday when I call in for some more parts quotes. A bushing would probably require turning the shifter ID.
The Quicken-keeper refuses to let me buy that $5000 mill/lathe :(
Addendum ............................
ID of shifter bolt hole = .675 (within spec)
OD of bolt = .665 (outer segment), .655 (inner segment) ... no spec
.010 - .020 is way too much, so I may just buy a new bolt.
Dana
1966/7 CB-77 Red of course
Superchicken
Post by Superchicken » Sat May 21, 2011 10:13 pm
Team cheep down here in Turlock Ca., has been known for using beer can to shim out a good part of the slop. Cut it with a scissor and then wrap it around the bolt .
Dana01
Post by Dana01 » Sun May 22, 2011 12:19 am
Hoo-ya!!! Love it. But that means I have to go buy cheap beer. Hmmm... may be a deal breaker.
I'll give it a try thanks :)
Dana
