Source for Cables
305explr
Source for Cables
Post by 305explr » Mon Aug 05, 2013 10:30 am
Hi all,
On my 64 cb77, I've gone from a higher type handlebar, to a broomstick bar. Rather than source each cable from different vendors, I'm hoping someone can point me to a single vendor who has both the parts and the knowledge.
-throttle
-fr brake
-tach
-speedo
Help appreciated. Thanks.
-Andy
Goodysnap
Post by Goodysnap » Mon Aug 05, 2013 11:16 am
Here is a cable set for the low bars. -
http://www.classichondarestoration.com/ ... d_216.html
The other three cables do not vary in length as they do not attach to the bars
Tach-
Rear brake-
I guess all that leaves is the speedo? might be as close as you can get with the same vendor.
64' CB77
65' CB160
305explr
Post by 305explr » Mon Aug 12, 2013 4:29 pm
This is great, thanks.
2_Hawks
Post by 2_Hawks » Thu Aug 15, 2013 3:46 pm
If you replace the speedo cable there is a difference between the superhawk and scrambler. The speedo drive hub threads for the cable are bigger on the scramblers. Tim at classic Honda restoration can get you the right one.
