Found a stop switch boot (sort of)
cdhe
Post by cdhe » Mon Feb 22, 2016 8:09 pm
Here's a pic of the "harness connector cover" I got from Cycle Terminal. I cut down the length a bit, and (at 22mm ID) it fits a little big, but not bad. Would love hear about other alternatives. Thanks!
https://www.flickr.com/photos/138222297 ... res/212643
Re: Found a stop switch boot (sort of)
Post by Seadog » Mon Feb 22, 2016 10:18 pm
cdhe wrote:Here's a pic of the "harness connector cover" I got from Cycle Terminal. I cut down the length a bit, and (at 22mm ID) it fits a little big, but not bad. Would love hear about other alternatives. Thanks!
Brake switch rubber cover? $12 from http://www.claussstudios.com/id45.html
Goodysnap
Post by Goodysnap » Mon Feb 22, 2016 10:18 pm
I used a piece of black adhesive lined heat shrink that turned out ok. Plus its sealed water tight.
64' CB77
65' CB160
