recommended motor oil for CL77
ccscrambler
Post by ccscrambler » Fri Dec 30, 2011 11:13 pm
I have several CL77s and really love these bikes. I believe the manufacturer's original recommendation for motor oil was 30 weight non-detergent, which is what I have used over the years. A couple of years ago I asked my Honda dealer what he recommended and he said 10/40 weight detergent. The 30 weight non-detergent oil is impossibe to find where I live unless I am willing to use 30 weight non-detergent compressor oil found at the local True Value Hardware store. It is on the shelf with all the automotive oils. However, this oil is not sanctioned by ASI or SAE and I'm not sure if I should be using it my CL77s.
What is your opinion, in general, about the use of the 30 weight non-detergent oil? If this is the best option over multi grade detergent oils? If this is the best option, is the compressor oil I describe above a good choice or should I insist on automotive ASI or SAE 30 weight non-detergent oil?
Also, the new oils have an ASI grade SN designation which I am told has little or no zinc in its formula unlike the previous SM designation which does have zinc. Should I avoid the newer SN oil, and if I'm forced to use it, should I be adding a zinc additive.
Thanks for any assistance on these matters. I want to give these old scramblers the best care I possibly can.
Thanks again,
ccscrambler
RobCL77
Post by RobCL77 » Sat Dec 31, 2011 10:32 am
CC,
There was a thread under the Motors category on December 8, 2008 that covered this exact subject about 17 pages worth. You might get your question answered there.
Rob
1967 CL77
ggray
CL77 oil
Post by ggray » Fri Jan 13, 2012 8:42 pm
NAPA has 30 weight non detergent oil. I use it in my '65 CL.
Gary
'65 CL77 Owner
