Beginning Restoration
Post by G-Man » Mon Feb 15, 2016 5:17 pm
My chromers don't like doing them unless they've been taken apart.
LOUD MOUSE wrote:I've have many of these same parts chromed and ALL come out GOOD. ...............lm
G-Man wrote:I make my own rivets in stainless steel.
You could probably find some straight pins which would take a split pin or "R" clip to secure them.
Post by LOUD MOUSE » Mon Feb 15, 2016 6:28 pm
Never a problem here and I've used several shops. .....................lm
G-Man wrote:My chromers don't like doing them unless they've been taken apart.
HondaPaul
Post by HondaPaul » Mon Feb 15, 2016 8:10 pm
That's interesting Ed. I just assumed that everything would have to come apart. I will talk to my chromer and see what he says. G-Man, impressive results. May I ask how you peen the rivets? Hydraulic press with a custom die maybe?
Thanks guys!
Paul
Post by G-Man » Tue Feb 16, 2016 2:40 am
Paul
The first ones were hammer peened but I think any more I do will be done hydraulically. I have always taken mine apart. I like to tighten up the pivot clearances where necessary.
"Front of House" at my favoorite chromers is a lovely lady who examines everything you take in and puts sketches down on paper to avoid disappointment. Electrolysis is a 'line of sight' process so she insists that things are dismantled before they do their work. They also make a beautiful job of CL rims when most people here won't even touch them.
HondaPaul wrote:That's interesting Ed. I just assumed that everything would have to come apart. I will talk to my chromer and see what he says. G-Man, impressive results. May I ask how you peen the rivets? Hydraulic press with a custom die maybe?
Thanks guys!
Paul
OldScrambler
Post by OldScrambler » Tue Feb 16, 2016 11:27 am
G-Man.......looks like a modern version of 'CROWN JEWELS'
My local chrome shop will do the linkage with the pins in-tact. They tape the rivet-head and plug the threaded areas. They tell me they 'swivel' the joint with a wooden stick while in the plating process.
HondaPaul
Post by HondaPaul » Sun Feb 21, 2016 8:39 pm
Hi all,
I have another plating problem. I would like to re-chrome the taillight back plate. However, it does not appear to be designed for disassembly. It looks to me that the thing is held together by a "rivet like" mechanism attached to the back of the light socket. I could try to peel the lip up but am not very confident of getting the assembly back together as tightly as it is now. Any suggestions?
Paul
ImageTaillight by , on Flickr
jsmith1107
Post by jsmith1107 » Thu Mar 10, 2016 9:21 am
Hi Paul,
JD will do those brake linkages intact--not a problem---he did mine and they turned out great. Looks like you are missing the chain guard unless I missed it earlier in the post saying you did in fact have it. Not sure if you have a sandblaster yet but Eagle Manufacturing is the one that did mine--they did a great job on all of the parts, including the small little pieces.
1974 Yamaha DT125 Enduro
1974 Harley Davidson AMF X90
1976-7 Yamaha XS 650
2-1966 Honda Scrambler
1973 Suzuki T500 Titan
