sibes67
Post
by sibes67 » Tue Dec 11, 2012 10:45 pm
Just wondering about that top hole. I have seen other front fenders close to the tire, yet some much more distance between top of tire and bottom of fender. I would like to move mine down, to get the fender tighter to the tire, so I assume I use that top hole to accomplish this. Currently there is a clip in the first hole (one closest to the ground), which I do not see in any parts manual. Not sure if that is even needed there. Just wondering. Thanks.
Frt Fork 1 by
sibes67, on Flickr
Post
by LOUD MOUSE » Tue Dec 11, 2012 11:05 pm
The fender stay is not installed correctly.
You will find that were you to remove it and the bottom bolt it will fit as designed. ........lm
sibes67 wrote:Just wondering about that top hole. I have seen other front fenders close to the tire, yet some much more distance between top of tire and bottom of fender. I would like to move mine down, to get the fender tighter to the tire, so I assume I use that top hole to accomplish this. Currently there is a clip in the first hole (one closest to the ground), which I do not see in any parts manual. Not sure if that is even needed there. Just wondering. Thanks.
Frt Fork 1 by
sibes67, on Flickr
sibes67
Post
by sibes67 » Thu Dec 13, 2012 7:03 pm
Thanks LM, got it corrected and re-installed. Turns out there was an extra hole drilled in between the stock 2 holes.
Post
by LOUD MOUSE » Thu Dec 13, 2012 7:23 pm
I saw that. ..lm
sibes67 wrote:Thanks LM, got it corrected and re-installed. Turns out there was an extra hole drilled in between the stock 2 holes.
sibes67
Post
by sibes67 » Fri Dec 14, 2012 10:47 am
Ever seen a clip like this before? Just curious if it is from another bike, another model, or what?
Fender Stay w/extra brace by
sibes67, on Flickr
Post
by LOUD MOUSE » Fri Dec 14, 2012 4:22 pm
It's custom made to raise the fender. ............lm
sibes67 wrote:Ever seen a clip like this before? Just curious if it is from another bike, another model, or what?
sibes67, on Flickr
