Engine seized
Engine seized
Engine seized while running. Took my CA77 for a test ride, and it ran fine for 26 miles, within a 1/2 mile of home running about 30mph the engine all of a sudden seized. With a wrench on the crank nut the engine will turn very hard. Removed the clutch so as to turn only the engine, very hard to turn. Removed plugs oiled the cylinders same problem. Drained oil and found nothing like metal in the oil, it was fresh oil and looked like it. Prior to the engine stopping I did not hear any tell tail sounds, it sounded great. Any suggestions would help please.
Re: Engine seized
Bad luck.
Have a look at the starter clutch on the other end of the crank. You'll have to pull off the generator and will need an M16 x 1,5 bolt as a puller.
Sometimes the starter clutch screws back out and jam on the crankcase.
Alternatively, was the engine hot at all?
What color wre the plugs?
coolmg wrote:Engine seized while running. Took my CA77 for a test ride, and it ran fine for 26 miles, within a 1/2 mile of home running about 30mph the engine all of a sudden seized. With a wrench on the crank nut the engine will turn very hard. Removed the clutch so as to turn only the engine, very hard to turn. Removed plugs oiled the cylinders same problem. Drained oil and found nothing like metal in the oil, it was fresh oil and looked like it. Prior to the engine stopping I did not hear any tell tail sounds, it sounded great. Any suggestions would help please.
Engine seized
Engine was hot, I had just ridden it 26 miles. Plugs looked grey, were not white like it ran lean.
OldScrambler
Was that the starter clutch or the transmission clutch?
coolmg wrote:You were correct two bolts on the clutch were loose, and one was broken, engine is fine. My next question is when I reinstall clutch with a new kit what do I lubricate it with? Thanks again for advice.
