1966 dream, blackened plugs...
sky1haze
Post by sky1haze » Mon Sep 13, 2010 7:39 pm
I have a problem with my plugs getting all fowled up, turning really black and having to be replaced every-every other day........any suggestions....
Oh yeah, It backfired a few times today while trying to start it....
brewsky
Post by brewsky » Mon Sep 13, 2010 8:21 pm
Clean the carb (all jets and passages), adjust the float and idle, check air filter, adjust the valves, adjust cam chain, check timing, then go from there if necessary.
Had a similar prob with mine in the beginning...turned out I was setting the float to the wrong spec.
Correct setting is 26.5 mm from gasket surface of carb body.
sky1haze
Post by sky1haze » Mon Sep 13, 2010 9:19 pm
thank-you so much, as a beginner, this seems to be a big project.....Time to learn!
sky1haze
Post by sky1haze » Mon Sep 27, 2010 1:42 pm
do you have a simple way, or know where I can go to learn how to adjust my valves??
-joel-
_______________________________________
1966 CA77
