wiring of coil
wiring of coil
Could someone remind me on how the wiring of a coil? Does the green wire connect to positive side of coil and black wire on the negative side? Or is it the reverse order? Also, my ca77 has two wires on the ground side of the battery, does both of the wires connect to the grounding on the frame? As you can see, I'm not much on wiring, I just love to ride!!! Not only blowing my mind,but, I'm keeping Autozone 15 amp fuse business alive!!!
