Help me diagnose a ticking noise? Video attached.
Cheburashka
Post by Cheburashka » Wed Sep 05, 2012 3:34 pm
I've got a bad tick coming from the engine. Can't quite figure out where it's coming from. Sounds like once per revolution and most pronounced at idle. Cam chain tensioner and valves have been adjusted and bike has fewer than 3000 miles on it. Any ideas?
http://www.youtube.com/watch?v=LIAMchZe ... e=youtu.be
Re: Help me diagnose a ticking noise? Video attached.
Post by LOUD MOUSE » Wed Sep 05, 2012 6:46 pm
I'd say you need to do the valves again. ............lm
Cheburashka wrote:I've got a bad tick coming from the engine. Can't quite figure out where it's coming from. Sounds like once per revolution and most pronounced at idle. Cam chain tensioner and valves have been adjusted and bike has fewer than 3000 miles on it. Any ideas?
Cheburashka
Don't think it's the valves
Post by Cheburashka » Wed Sep 05, 2012 8:00 pm
I adjusted the valves with zero play and I'm still getting the same noise. Any other guesses as to what it might be?
DONZIE
Post by DONZIE » Wed Sep 05, 2012 8:43 pm
I don't mean to question your ability...but I would say go back to the valve adjustment one more time also
jensey
Post by jensey » Thu Sep 06, 2012 2:05 am
If you are sure on the valves, look for a too loose the cam chain.
BCSANDERS
Post by BCSANDERS » Thu Sep 06, 2012 7:37 am
On my motor the 4 rivets that are part of the cam sprocket assembly were slightly loose and gave a very similar ticking noise .
I just hammered them over a bit to tighten them.
Cheburashka
I'll check the timing chain and sprocket rivets.
Post by Cheburashka » Thu Sep 06, 2012 8:15 am
I'll be pulling the cam cover to check those things out. I was wrong about the mileage. It's around 5200. Still not a lot.
I'm thinking I may as well replace the timing chain while I'm in there. Any advice regarding endless or master link? Obviously I'd rather do the master link style since there's less dis-assembly required. Where can I get a good quality chain?
