                    Oil from breather pipe
				Geoff Hastings
Hi there,
I've just fired up my CA77 for the first time. The bike was bought at an auto jumble and I did strip the engine and examine it. Despite the speedo reading 14,000 it was on 1mm oversize Pistons so has done quite a few miles. The bores were OK, you could still see the honing marks and ring gaps were correct so they were left. I just changed the cam chain and reassembled the engine, after a short run there was a fair amount of oily vapour dripping out the cylinder head breather pipe. I'm kind of hoping that it's not excessive blow by causing this, can anyone advise please.
One thing to check is that you assembled the plate on top of the head the right way around as it forms a labyrinth to separate oil from any air being pumped out.
https://www.cmsnl.com/honda-cl72-scramb ... SXwOcm1vpg
Did you hone the bore at all to break up any glaze?
New rings or old?
Fit of valves in guides?
New rings or old?
'60 C77 '60 C72 '62 C72 Dream  '63 CL72
				Geoff Hastings
G-Man wrote:One thing to check is that you assembled the plate on top of the head the right way around as it forms a labyrinth to separate oil from any air being pumped out.
New rings or old?
The bores were not glazed, honing marks still visible, I did reuse the rings as the gaps were within limits. Valves were OK in their guides but I was a bit puzzled by the lack of stem seals. I must admit that I reassembled the plate the way it came out but that's not say it was put together properly the last time. I did find a crack in the cases as they had not aligned the main bearing pins with the holes correctly and then tightened the case bolts. Looks like I'll have to pull the top end apart again.
If the breather effluent is being caused by blow-by from the rings not seating, you may as well run the bike for a while to see if they bed in. Put a little catch bottle at the end of the breather tube and see how much is actually being spit out - a little mist is nothing to worry about.
Didn't over-fill the crankcase with oil by any chance?
Valve guide seals not needed.
				Geoff Hastings
Thanks Nick and G man, I'll probably run it as suggested with a catch bottle for a few days. There was no smoke in the exhaust and I did only run it for about 10 minutes.Nick wrote:If the breather effluent is being caused by blow-by from the rings not seating, you may as well run the bike for a while to see if they bed in. Put a little catch bottle at the end of the breather tube and see how much is actually being spit out - a little mist is nothing to worry about.
I found another problem at start up, the fuel tap bowl had a pin hole in it and this leaked fuel all over the freshly painted engine, which I then found out was not fuel resistant so most of the paint ended up on the drive. Oh well.
				Geoff Hastings
New rings or old?
Hi G-Man. As I have a bit of time before I can get the bike uk registered I decided to pull the top plate off the engine and check whether I had put the baffle plate on the right way round as suggested. There was no baffle plate fitted! I did wonder at the time why the gasket kit had two gaskets and looking at an exploded view it's obvious but I re-built the engine as I found it without a manual. Strange why someone would leave out part of the engine, it's not as if it wears out. Anyway, I've ordered a new one. Thanks for the info.
