Clutch issues
gearhead3275
Post by gearhead3275 » Fri Oct 23, 2015 8:08 pm
Got the cover off finally used a impact driver. When I pull in the clutch lever the clutch plates move in and out together. Everything looks good and very very clean if that means anything. Still have the clutch failing to engage to let the bike out of gear.
mike1969
clutch
Post by mike1969 » Fri Oct 23, 2015 8:54 pm
Do the plates separate when you pull the clutch lever? Plates shouldn't stick together.
gearhead3275
Post by gearhead3275 » Fri Oct 23, 2015 9:26 pm
Does not appear so, they all move in and out together. Its like one single unit moving in and out when the clutch lever is pulled.
clutch
Post by LOUD MOUSE » Fri Oct 23, 2015 9:47 pm
I recommend you remove the 4 bolts which hold the pressure plate.
Remove the pressure plate and take all the friction/steel plates from the clutch outer case.
You should find that there are 2/3 wires holding the last parts and you will need to pinch the ends and push the ends out of the case.
Clean all parts with what ever you have used to this time but Do Not Use CARB. cleaner. .................lm
gearhead3275 wrote:Does not appear so, they all move in and out together. Its like one single unit moving in and out when the clutch lever is pulled.
gearhead3275
Post by gearhead3275 » Fri Oct 23, 2015 9:56 pm
Ok, I'll get to it first thing Saturday morn. Thank you
gearhead3275
Post by gearhead3275 » Sat Oct 24, 2015 9:11 am
Well gentleman I removed the clutch and it came off in one complete solid lump. Cleaned it up and put it back on this morning.. Appears to work good. Thank you for taking the time to give input to a new guy.....steve
