My timing
Post by LOUD MOUSE » Wed Aug 25, 2010 9:14 pm
You should have 12 volts at the coil when the key is in the correct ON position.
I meant sort of an unknown fault like short, broken wire, wire in the wrong place.
More like something wrong but I'm not sure where or what. .........lm
Eljeef wrote:
LOUD MOUSE wrote:Possible ya have a wiring fault.
I must have had my Eyes Crossed.
I would have bet ya had 8 numbers.
My Bad!. .........lm
Those zeros still mess me up. :0 Should I have 12 volts at the coil wire at all times or just when the key is on? My bet is just when the key is on so the battery doesn't drain. When you say wiring fault, are you talking about an exposed wire grounding out somewhere or possibly frayed and not allowing enough juice through?
Eljeef
Post by Eljeef » Thu Aug 26, 2010 9:15 pm
LOUD MOUSE wrote:You should have 12 volts at the coil when the key is in the correct ON position.
OK I'll get at it. Thanks.
1964-C77 305 Dream
2002 BMW R1150GS
