oil capacity
kevinral
Post by kevinral » Mon Mar 28, 2011 8:59 pm
Thanks all for the feedback. The 'no screw' makes since now (i.e. 1.7 qt.). Thanks to the best forum on the 305!
Just curious, is there a secret about getting the screws loose for the oil filter? The screws that I have are phillips and are rusted. I have been hitting them pretty hard with WD but they won't budge. Maybe get the motor hot and then try (provided I can get her started)?
Goodysnap
Post by Goodysnap » Tue Mar 29, 2011 5:17 am
http://www.amazon.com/Lisle-30200-Hand- ... B000P0TZ9W
This tool will be of help on your stubborn phillips screws.
64' CB77
65' CB160
brewsky
Post by brewsky » Tue Mar 29, 2011 6:12 am
First, make sure you have the right driver tip or bit.
It should go completely into the screw with no slack.
I use a T-handle screwdriver and dip the tip in valve grinding paste to increase the bite on the screw.
Then smack it in a couple of times with a hammer which can help break the bond of the corrosion.
Then push in as hard as you can with the driver and give a quick, sharp twist.
If that doesn't work, I break out the drill and vice grips.
jensen
Post by jensen » Tue Mar 29, 2011 6:59 am
If an impact driver doesn't find the grip anymore, and all other options are gone, there is one thing you could try before you drill or weld it.
Take a hammer (which I officially don't have in possession), and a chisel (neither officially in my possession) and gently cut a straight slit in the screw. Take a large screwdriver and changes are it will come loose.
btw, I use diamond coated screwdrivers first, look at :
http://www.wihatools.com/700seri/700_diamondbits.htm
Post by davomoto » Tue Mar 29, 2011 9:18 am
Jensen,
Do you have a "Platinum" coated hammer as well? :-)
Davo
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
