My Stuck Pistons SOLVED
Post by G-Man » Thu Dec 06, 2018 10:09 am
Unfortunately the pistons I thought were CA77 are CB77.
All is not lost, though - I have found one CA77 STD piston.
Will keep looking.
Dr. Frankenstein wrote:Yup - my cylinders measure 59.85 all the way down, give or take one or two hundredths.
Dr. Frankenstein
Post by Dr. Frankenstein » Thu Dec 06, 2018 10:52 am
I Think Standard-size CB77 pistons ARE 60mm...aren't they ?
Post by G-Man » Thu Dec 06, 2018 10:58 am
They are indeed but the crown design is different from CA77 and might lead to a lower compression ratio.
That said, I do have some high compression ones.....
Let me rummage a bit more.
Dr. Frankenstein wrote:I Think Standard-size CB77 pistons ARE 60mm...aren't they ?
Post by G-Man » Fri Dec 21, 2018 11:52 am
Still unable to find a pair of 60mm CA77 pistons.
Dr. F
This is what I have. CB77 pistons in LC and HC. One CA77 Piston in the middle.
Cb77 pistons need to be tested with CA77 head but, if they clear, they should be OK.
Not perfect, but what is these days? :-)
