which side does the bolt/ground wire go?
jimpapa
Post by jimpapa » Mon Mar 26, 2012 8:00 am
rrietman wrote:J; I'm interested to know how you are fitting the dual carbs into the dream frame. pics?
Randy
as you can see here, there was a small notch cut out of the frame to fit the carbs.
i'm going to be putting the carbs back in this week and i'll post a pic when its all jammed in there
conbs
Cut frame
Post by conbs » Mon Mar 26, 2012 2:39 pm
J, did you put some kind of gusset in where the air filter used to go to strengthen your frame? Interesting conversion.
jimpapa
Post by jimpapa » Mon Mar 26, 2012 5:01 pm
mod was done by PO,
not worried about strength, only small bit is gone
Muddy
Post by Muddy » Tue Mar 27, 2012 4:24 am
G'day jimpapa
Wow, that sure will be an interesting hybrid when completed - you'll have to keep us all informed how it goes.
If that cut out of the frame isn't reinforced, I'd be a little worried about the loss of strength and rigidity in that area - even though the engine will provide significant bracing.
Maybe as conbs suggested, possibly a little gusset wouldn't hurt? Anyway good luck with the project - keep everyone posted. Can't wait to see how it looks and goes.
Thanks.
Regards
Muddy
'64 C72
'63 C72
