Dream Mufflers
Rogermeiner
Dream Mufflers
Post by Rogermeiner » Sat Feb 02, 2008 3:10 pm
I have a set of 1964 ca77 mufflers Good news-no rust, bad news-dents. Has any one had luck at cutting the seams. fix the dents and re-weld than re chrome ? Or spot welding on pins and pull the dents out. Any suggestions appreceiated.
Post by 305 » Sat Feb 02, 2008 6:00 pm
just a thought....if you pulled the baffles out could you get a tool in there to work them out?
if that doesn't work you could try the welded on pins like the body shops use , they go on with a special spot welder tool as you seam to be aware,and the use the puller . if all the spot welds were on the bottom you could just touch them up with some stainless steel paint
on my own CA77 i did some repair on the bottoms with my tig welder and touched them up , no one notices
neus68
Post by neus68 » Mon Feb 04, 2008 10:12 am
I am currently in the process of fixing up one of my mufflers. Yes, I cut it in half at the seam. It seemed to work pretty good. It allowed me to hammer out the dents. The seams are a little larger, but once I do some more work, I am sure it will be fine. The only thing to keep in mind to keep the cuts shallow because there are several baffles in the pipes. I hope this helps!
1967 CA77 Dream
1965 CA77 Dream In Process
1968 Z-28
