                    Kick starter slips occassionally
I have a 1969 CA 77 Dream -new to me. The kick starter lever works well but every few kicks it slips down with little resistance and does not turn over/engage the engine. There is no noise associated with these events and the splines on the pawl look fine. Any thoughts? Thanks! Jeff
Re: Kick starter slips occassionally
Inside the gears is a Kick Starter Pawl which wears and I'd say that's what ya have.
Not uncommon. ...........lm
jjjjjj wrote:I have a 1969 CA 77 Dream -new to me. The kick starter lever works well but every few kicks it slips down with little resistance and does not turn over/engage the engine. There is no noise associated with these events and the splines on the pawl look fine. Any thoughts? Thanks! Jeff
Screw for kick starter inside?. ...........lm
pwilke1 wrote:Try tightening the screw on the bottom of the kick lever. This is inside the side case but can be accessed though the view hole under the rubber cap. I had the same issue a few months back and this solved the problem.
-Patrick
Ya will need to split the cases in either case.
The bushing which wears is the 14mm brass one and the area where the 12 rollers contact the shaft is where the shaft wears.
I haven't seen the end bushings wear the shaft but do see the end one where the pawl rubs wear from the contact with the pawl and need replacing. ..................lm
nc_rider wrote:loud mouse... to replace that worn pawl (28255-250-020 ?) do you have to split the cases?
And does worn bushings (at either end of the kick starter spindle) add to this issue? (and I'm assuming you have to split the cases to replace them.
Are the affected parts (pawl, bushings, spindle) available from somewhere?
It also looks like the CA shares these parts with the CB and possibly the CL??
and.. it looks like there's a small spring and pin that pushes the pawl out? If it's gummed up (or the spring weak) would it prevent the pawl from engaging?
also, it looks like that 14mm bushing is what first gear spins on. Is there anyone making a "new and improved" version to better handle wear?
