Hello all...
Here is the situation...  My 1964 Ca77 has been running perfect for several months, starting every time.  Now all the sudden my left plug (both plugs are only a few months old) isn't sparking.  I've verified the following:
-  points are gapped appropriately and clean
-  timing is right on
What would you recommend I look at next?...  condensor, coil, trimming back plug wire?
Thanks for your help...
                    Spark Issues - Need Advice
				Hoosier Tom
No Spark
If one side fires fine, it won't be your points or condenser.  Hoosier's right.  Swapping the wires will tell you if it is in the wires or in the plugs.  Trimming wires won't help if you have a bad plug.  Changing plugs won't help if you've got a problem in a wire.
Let us know what you find out.
