Walmart Battery
cadman
Walmart Battery
Post by cadman » Tue Dec 11, 2012 7:01 pm
Walmart battery - ES12N94B1 - fits 1966 Dream - Walmart #001020597
FluteTears
Re: Walmart Battery
Post by FluteTears » Tue Dec 11, 2012 9:19 pm
cadman wrote:Walmart battery - ES12N94B1 - fits 1996 Dream - Walmart #001020597
1996 Dream?
1974 CT90
1964 CA77
bbap
Re: Walmart Battery
Post by bbap » Tue Dec 11, 2012 9:29 pm
I've done a comprehensive review using the search function and cannot find any other 1996 Honda Dreams. Please post a picture asap. :)
CA78 - 3111XX - Frame
CA77E - 3161XX - Engine
lrutt
Post by lrutt » Wed Dec 12, 2012 10:27 am
sealed battery or flooded?? I'd never put another flooded battery in a bike given the risk of an acid mess. AGM all the way baby.
Tinman
Post by Tinman » Wed Dec 12, 2012 11:18 am
It's a lead acid battery, non-maintenance free. I would suspect that if your charging system has a habit of over-charging or charging at a higher rate than what a Dream's system puts out, then I can see where boiling over would be a problem. But the charging system on a CA77 is anemic at best.
I have one in my Dream going on 6 months now and I haven't had a problem and I check it regularly. I also maintain it with a float charger so its going all of the time.
The problem I ran into, which isn't really a problem as much as it is an inconveinence is that the posts are reversed. Instead of returning the battery I made up a longer ground lead to attach to the provided ground on the frame. So that mistake was on me.
I've heard of the gel cell and Li-Po batteries bulging from over-charging, I'm not sure if the AGM type batteries fit into this catagory as I have no knowledge or experience with them.
But for a cheap battery, Walmart is suitable.
Tinman
lrutt
Post by lrutt » Wed Dec 12, 2012 11:27 am
All I know is no matter how carefull you are, it seems the terminals will grow green crud from time to time.
I've had an AGM in my 305 now for over 8 years, no problems. And I do keep it on a tender when not in use.
linemup
Post by linemup » Wed Dec 12, 2012 12:35 pm
Does anyone know if a battery can be purchased from walmart for the 61 dream? if so, what brand and battery number.
