FIBER FRICTION CLUTCH PLATES
FIBER FRICTION CLUTCH PLATESI ordered a set of clutches for a 1966 305 Dream.....The clutches seems to be a hair smaller that the originals..... I heard that some have 3mm and some have 4mm...... Is there a big difference and will the smaller one work ??????????????????
http://www.honda305.com/forums/305-clut ... everything clutch plate
Check this link and it should answer your questions, but simply a complete 4mm or 3mm clutch will work. There 4,5 and 6 plate setups, so you need the right amount for your total stack thickness to be correct. 63 CA78
