CA77 springs for spirited riding, not Shriner parades?
Cheburashka
Post by Cheburashka » Sun Apr 14, 2013 10:39 pm
I'm enjoying my '64 CA77, but I find that the ride is decidedly "squishy." It's nice most of the time, but I've been known to bottom out the suspension with my 178 pounds and this makes me uncomfortable. I'd like to know if there's a way to stiffen up the springs on the front and the back to make the bike handle a bit better.
Thanks
mike1969
dream shocks
Post by mike1969 » Mon Apr 15, 2013 6:57 am
I saw a Dream for sale on ebay several years ago that had chrome spring rear shocks. Someone asked what kind of shocks he used and he said they were from a Honda 250 Shadow.
Tinman
Post by Tinman » Mon Apr 15, 2013 8:40 am
Chebur,
Here are several links that will probably work for you. The length on both are in the ballpark, its the diameter of the mounting eye that may be of concern. You may have to figure out a way to enlarge the eye's diameter if its too small. Both are adjustable to your riding style. The Rebel shocks will work as the shock diameter is just narrow enough to clear the fender bracket. Sorry but I can't help you on the front springs. Perhaps someone else has an answer.
Tinman
http://www.ebay.com/itm/HONDA-CA72-CA77 ... 2ec162265a
http://www.ebay.com/sch/i.html?_odkw=ho ... s&_sacat=0
conbs
Shocks
Post by conbs » Mon Apr 15, 2013 10:00 am
That soft ride is part of the charm of riding a Dream. Bill Silver describes it as "riding on a cloud". My '65 has bottomed out, but doesn't all the time. I have been over 200 lbs a good share of my riding time.
Are you sure your shocks aren't just worn out?
Cheburashka
Re: Shocks
Post by Cheburashka » Mon Apr 15, 2013 5:20 pm
conbs wrote:That soft ride is part of the charm of riding a Dream. Bill Silver describes it as "riding on a cloud". My '65 has bottomed out, but doesn't all the time. I have been over 200 lbs a good share of my riding time.
No way. They're only 50 years old. ;)
I guess it could be bad shocks, but since I do feel like I'm riding on a cloud and not a hammock, I'd be inclined to think that they're performing as intended.
rrietman
Post by rrietman » Mon Apr 15, 2013 11:29 pm
C; you could fit up some rear shocks, but they will look shitty. the fronts are impossible. get some good modern tires, pump up the pressure and you will be surprised at what that dream can do.
Good luck
Randy
Cheburashka
Post by Cheburashka » Tue Apr 16, 2013 12:39 pm
rrietman wrote:C; you could fit up some rear shocks, but they will look shitty. the fronts are impossible. get some good modern tires, pump up the pressure and you will be surprised at what that dream can do.
Good luck
Randy
I've got modern tires (with Portawalls of course) and the cornering is remarkably good. I just hate that feeling of going into a corner and having no more compression to the springs. It makes things a bit unpredictable.
I guess I'm stuck with it though. I don't ride a Dream because of the handling. I ride it because it looks cool. Rebel shocks would mess that look up.
I'm wondering about preload bushings on both springs.
