Introduction--Hey y'all!
coffee_brake
Post by coffee_brake » Wed Nov 16, 2016 11:52 pm
The ebay auction has ended, the deposit has been sent, and the final payment details have been hammered out--I suppose I'm about to bring home a '66 300.
I didn't pay very much, and it shows. But it's about perfect for what I'd like to do: ride and enjoy an older bike and replace/modify only what really needs it, without worrying about destroying a museum or show-quality piece. I won't be cutting or hacking away at anything, but I might use aftermarket stuff like cables or plug wires or grips without bothering to make it stock.
The other bikes in my stable are fairly modern carbureted machines, but there's a '79 CX500 in the mix too, that needed EVERYTHING when I got it. After attending a few vintage motorcycle rallies like Mid-Ohio and Barber, the Dreams kept getting my attention. Finally found one far from perfect but not butchered, so here I am.
I'm still trying to figure out the differences in the models. I'm still not clear on the 300/305 engine differences, and haven't found a manual for this particular model, but I know there's good info for the asking.
Thanks for having me!
Re: Introduction--Hey y'all!
Post by LOUD MOUSE » Thu Nov 17, 2016 7:55 am
Welcome.
These bikes were issued with 246CC (250) and 305CC engines.
Never a 300CC. BADGES DO SHOW 250 AND 300.
Many other bike manufacturers did the same numbers swap to keet the size comparable with each other. ...................lm
coffee_brake wrote:The ebay auction has ended, the deposit has been sent, and the final payment details have been hammered out--I suppose I'm about to bring home a '66 300.
bodie1204
Post by bodie1204 » Thu Nov 17, 2016 4:30 pm
Welcome to the board, great info here.
coffee_brake
Post by coffee_brake » Fri Nov 18, 2016 10:56 am
I'll be able to get the bike right after Thanksgiving. Supposedly it's a battery and carb flush away from running.
Are there any issues I should understand that would make this start-up any different from most other bikes? Any fragile parts, or likely-to-fail, or hard-to-find parts that I should be ready to address and make sure I don't damage?
Are there any special tricks to the job of removing the tank and carb to clean? Do I need any special tools to maintain this model?
Other than a bit of oil down the spark plug holes to ease the rings' initial movement in the cylinders, is there anything I should do to the motor before running it?
This is a 12-volt system: how different will it be from the 80's bikes I've already worked with? It's got a funky regulator for sure. Should I expect it to charge at about 13v?
Will I find anything surprising with the way the clutch and brake cables operate? I haven't adjusted front drums before.
I just don't want to screw something up by transferring my experience with 80's and up bikes to this older machine. I REALLY APPRECIATE advice! Ignorance is inevitable, but staying ignorant when knowledge is in reach is unacceptable.
Post by LOUD MOUSE » Fri Nov 18, 2016 12:16 pm
Now is a perfect time for you to search eBay for a CLYMER manual which will answer your questions now and later. ................lm
coffee_brake wrote:I'll be able to get the bike right after Thanksgiving. Supposedly it's a battery and carb flush away from running.
coffee_brake
Post by coffee_brake » Fri Nov 18, 2016 2:14 pm
Those are going for over a hundred bucks!
Or did you mean the Clymers Collection Series Vintage Japanese Street Bikes Motorcycle Manual?
Is this what I want?
http://www.ebay.com/itm/Clymer-Collecti ... 4u&vxp=mtr
or this?
http://www.ebay.com/itm/Honda-CL72-250- ... GJ&vxp=mtr
Post by G-Man » Fri Nov 18, 2016 4:08 pm
You could try downloading this from Kevin at Scrambler Cycle. He is on this forum as Hahnda
http://www.scramblercycle.com/uploads/3 ... manual.pdf
