Cables - Early vs Late
Dr. Frankenstein
Post by Dr. Frankenstein » Fri Apr 05, 2019 5:51 am
Is there a difference in the control cables for the Early vs Late model CA77? Is one set longer than the others?
Part numbers don't really tell me anything...
Hahnda
Post by Hahnda » Fri Apr 05, 2019 12:15 pm
Only the clutch cable has a long and short version. The early cable is longer as it is routed back through the sidecover and then forward.
rrietman
Post by rrietman » Fri Apr 05, 2019 7:09 pm
Also the early (twist) vs late (slide) throttle cables.
Good luck
Randy
Dr. Frankenstein
Post by Dr. Frankenstein » Sat Apr 06, 2019 12:47 pm
Yeah, I'm learning a Lot about so-called interchangeable parts over Ten model years...Early vs Late makes a huge difference...
Dr. Frankenstein
Post by Dr. Frankenstein » Mon Apr 08, 2019 5:51 am
What's the trick to getting the front brake line installed in it's mount on the front wheel cover...?
