I may have to replace my condenser, and rather than drop the motor to do it I'll probably disconnect the old one and mount a new one in a new spot. I'm a picture guy-- seeing it helps me figure things out, so if you have mounted a condenser for a CA77 in an alternative spot and can post a pic that would be very helpful.
If there is one already posted somewhere that someone could point me to that would be great as well.
Alternative locations for Condenser
See here:
http://www.honda305.com/forums/viewtopi ... =condenser
Most common seems to be at the cam chain tensioner (maybe because you don't have to splice any wires)....but it doesn't look the best...here's mine
I will eventually move it under the coil cover or under the points cover.
