Somethings Not Right
Davo
Post by Davo » Sun Mar 04, 2012 1:39 pm
Had this CA77 for about 2 months now seems to run good and sounds fine. but since it has been cold here difficult to start and one pipe gets hot the other cold, even after i let it warm up for 20 minutes. pulled and cleaned plug fire-up still cold the plug appears to be fouling out any thoughts ?
Re: Somethings Not Right
Post by LOUD MOUSE » Sun Mar 04, 2012 7:33 pm
Coil wire to that side.
Cap on that side. (swap to see if it's the cap)
Valves on that side. ...............................lm
Davo wrote:Had this CA77 for about 2 months now seems to run good and sounds fine. but since it has been cold here difficult to start and one pipe gets hot the other cold, even after i let it warm up for 20 minutes. pulled and cleaned plug fire-up still cold the plug appears to be fouling out any thoughts ?
Post by davomoto » Mon Mar 05, 2012 9:11 am
Is it getting spark on that side? Compression test might be helful as well.
Davo
Davo
Post by Davo » Mon Mar 05, 2012 9:45 am
I will give both of those a try, I have been following this site for a couple of years, purchased and sold two bikes that were out of my skill base. finally have the dream I have been waiting for. thanks so much I will let you know how it goes. I hope there is enough room for two Davos..
