Greg -- What I have currently fitted is the oil filter conversion kit, and I just got the 6mm oil pump that we're going to install over the winter. I haven't done the oil cooler.Waveblaster wrote:Hi Vince
I understand that you have fitted the external Capelli oil cooler and filter. Have you considered tapping a sender unit into the external fitting. Might be nice to get reading of the oil temp and pressure. Not critical but perhaps a nice to have if you enjoy the mods. Would be interesting to see the before and after Capelli pump readings.
regards
Greg
Here is the oil cooler: http://www.ebay.com/itm/Honda-CB72-CB77 ... 13&vxp=mtr
As you can see, it's a bit of a monster! And from what I can tell, you'd need to remove the starter motor, which wouldn't be good for me as I no longer have the kickstart mechanism. So I don't think that modification is in the cards for me.
What I can say is that I think that oil filter conversion kit is a worthwhile consideration -- definitely is a better filtration method (at least from my non-mechanic perspective), and I actually found a bit more oomph at the rear wheel. The 6mm oil pump is just a bit of safety measure, though Cappellini says that the stock (4.5mm) pump works fine with the filter kit. Other good thing is that these particular modifications don't change the external look of the bike -- I have enough of that going on already!
I think what the bike really needs next year is a good long road trip -- maybe either Mid-Ohio again or something completely different.
