CA77 - CB77 Whats different aside from frame?
Head413
Post by Head413 » Fri Mar 05, 2010 3:21 pm
I need to know if things like the gas tank, engine, or other major assemblies are swappable between the two. I have a good CB77 frame and bits and have a line on a good cheap complete Dream. Thanks for any help, I know I could do a search and learn, but I'm pressed for time on this one.
mike1969
CA77
Post by mike1969 » Fri Mar 05, 2010 3:52 pm
There isn't much interchangeable other than the tank badges, the stator and possibly the starter.
Head413
Post by Head413 » Fri Mar 05, 2010 4:27 pm
Ok. Thanks for that. The hunt continues.
mike1969
ca77
Post by mike1969 » Fri Mar 05, 2010 7:20 pm
You're welcome.
teazer
Post by teazer » Fri Mar 05, 2010 11:36 pm
Aren't the bottom ends more or less the same - apart from the Type 1 type 2 crank? Barrels and transmission are the same too.Rockers are the same too. The head, cams, intakes, carbs and crank are different.
Rolling chassis - basically everything is different as already mentioned.
Post by LOUD MOUSE » Sat Mar 06, 2010 9:38 am
Alll gears are different. ..........................lm
teazer wrote:Aren't the bottom ends more or less the same - apart from the Type 1 type 2 crank? Barrels and transmission are the same too.Rockers are the same too. The head, cams, intakes, carbs and crank are different.
teazer
Post by teazer » Sat Mar 06, 2010 11:17 am
That's interesting. I never had a dream apart. What are the tooth numbers on the gears by comparison to CB?
