Generator Bolt Size??
Dr. Frankenstein
Anybody know what the size of the bolt is that goes through the spark advance generator into the stator on a 305 Early model...?
A parts bike I just picked up is missing that center bolt, and I need to try to turn the engine over by hand...It should be the same size as the on a 305 Late model, but the manual and parts list don't tell me anything.
Thanks!
-John
Thanks!
-John
Re: Generator Bolt Size??
M8 ISO Metric.
30mm long
23mm diameter washer 3.5mm thick
30mm long
Dr. Frankenstein wrote:Anybody know what the size of the bolt is that goes through the spark advance generator into the stator on a 305 Early model...?
Thanks!
-John
Dr. Frankenstein
Dr. Frankenstein
You can try heat but try and heat evenly and don't melt anything. Is the head off?
Dr. Frankenstein wrote:Man...this thing ain't budging...any ideas without taking the engine out of the frame? I've had the cylinders soaking in a soup of oil, Marvel Mystery Oil, PB Blaster, and whatever the PO said he put in there too...think heat might work?
