Need Help With Bike ID!
rr805
Post by rr805 » Fri Nov 23, 2012 3:56 pm
Hi all,
I'm new to the forum as you can tell, and I'm hoping you guys can help me pin down the details on this bike. Long story short, the guy in the photo is my dad, who has long-since passed on and is no longer around to help me get to the bottom of this. The photo was supposedly taken in June of 1967. After an extended break I've recently gotten back into bikes and would like to start a project restoring one like this. Obviously the first step is figuring out what it is :) I've spent a lot of time online trying to match up this bike with images of ones from the internet, and can't seem to match everything up, especially the proportions/configuration of the rear fender and seat/taillight bracket. A mechanic at a local bike shop suggested it was a 1964 or 1965 CL77 305 Scrambler. However, I was also finding some photos online of 1963 CL72s that were looking pretty similar. Any help would be much appreciated.
Thanks for your time-
Roger
Post by G-Man » Fri Nov 23, 2012 4:36 pm
It's either a CL72 (250cc) or a CL77(305cc). Pretty much the same bike except for a few details. They changed a little over the years and got bigger brakes and different fenders.
The 77 is more popular in the States because of the bigger motor. 72s are rarer and were phased out earlier.
rr805
Post by rr805 » Sun Nov 25, 2012 1:35 am
Thanks, G-man. I appreciate the input. I'm still trying to learn anything I can about the 72s and 77s. Looks like I'll be spending a lot of time searching/reading this forum.
CL72
Post by LOUD MOUSE » Sun Nov 25, 2012 2:19 am
The CL72/77 left side exhaust pipes were/are different at the front bend.
I'd say this is the CL72 pipe so tis possible it was a CL72. .........lm
rr805 wrote:Thanks, G-man. I appreciate the input. I'm still trying to learn anything I can about the 72s and 77s. Looks like I'll be spending a lot of time searching/reading this forum.
Tim Miller
Post by Tim Miller » Sun Nov 25, 2012 10:41 pm
Even early 77's had tight bend left pipes. I don't see two louvers on the chain guard. Might be a 305 ??
Tim
Post by LOUD MOUSE » Mon Nov 26, 2012 8:52 am
Best I can tell the oil filter cover and clutch cover are early issue.
I can't even see the rear of the chain guard and if you can do you also see a band at the front of the intake tube?. .lm
Tim Miller wrote:Even early 77's had tight bend left pipes. I don't see two louvers on the chain guard. Might be a 305 ??
Tim
Post by davomoto » Mon Nov 26, 2012 11:03 am
Rear fender has been "customized". You probably won't find another like it! Tank looks like it had mounts for rubber knee pads removed, and badge recesses filled. A popular "upgrade" back in the day :-)
Davo
