That's pretty enlightening. Thank you.
I see how the two angle can be so different now. I'll get you the spoke circle dimensions for the 160.
cknight wrote:Hi Graham, spoke angle is the angle between two radial lines drawn from the center of the wheel. One line going to where a spoke is centered in the dimple of the rim, and the other where the other end of that same spoke is centered in the hub flange. In wheel drilling it is a main point of reference. It's one of the dimensions used to calculate the angle that the rim is drilled for the spoke nipples. The rim diameter and the spoke diameter on the hub are other primary reference dimensions (among a few others). It's not the angle that the nipple protrudes from the rim, nor the angle between the spoke and a radial line. As the 160 wheels are also 18", but have a smaller spoke circle, the spokes are longer and "stand up straighter" than on a CB72/77, reducing the spoke angle. In a bit of "less than accurate" tracing using your 160 image, I attempted to guesstimate the spoke angle. Using my trusty plastic protractor, I came up with an angle in the low 20's, so not too far out of reason. Yes, the angle that the nipple comes out of the rim only changes slightly from one rim to the other (after all the calculations are made), but by the time it gets from the rim to the hub, it's a notable change. Hope I haven't made thing more complex. Thanks, Chase
