Any comments on aqua vapor blasting on engine cases etc...
Hahnda
Post by Hahnda » Mon Oct 07, 2013 11:17 am
I just had some CB77 parts vapor blasted at Rice Relics. Turned out great. Its like I'm putting together a new engine. I have done the bead blast and walnut shells in the past but this process is better in my opinion. About $350 including shipping both ways. These were some ugly and dirty parts when they left.
Bob750
Post by Bob750 » Sun Feb 23, 2014 6:33 pm
Here's another place I found for Vapor Blasting:
http://www.vaporblasting.biz/
Had: '75 CB550 K, '79 CT90
advantagecycle
Post by advantagecycle » Sun Sep 28, 2014 11:15 pm
My question is do they hold up though? If you spill oil, do they wipe off. Do they corrode easily, or turn colors with heat?
From what I've red it doesn't disturb the surfaces protective coating (clear anodize) so that would mean they are basically restored back to factory new correct?
Hahnda
Post by Hahnda » Mon Sep 29, 2014 8:03 am
In my experience it holds up great. If you spill oil on the surface it wipes right off and does not stain the surface. No discoloration from heat that I have seen.
The surface stays clean if you keep it clean. You treat it just like you would a new engine. New engines stay looking nice if you keep them clean.
No idea if vapor blasting will or will not remove anodize. I don't think any the parts on these old Hondas had any sort of anodize on them? At least not that I have seen or noticed.
malcolmgb
Post by malcolmgb » Mon Sep 29, 2014 5:25 pm
I have had my cases vapour blasted here in the UK recently, when I asked about keeping them clean he told me he uses a household furniture polish (silicon type) on his, they clean easily and have lasted some years. That is my plan when I finally rebuild the engine.
1977 CB400F
1973 CL175
1976 XL175 - Sold
1964 CL72
1966 CA78
cknight
Post by cknight » Mon Sep 29, 2014 5:50 pm
Wiping some ACF-50 on the bare aluminum will also provide a shine and inhibit corrosion. A very small amount will last a long time. Regards, Chase
Post by G-Man » Tue Sep 30, 2014 1:15 am
That sounds like a good plan!
I had my CB72 parts done at the Aqua Blast Center in Doncaster. Usually less that a week turnaround and very meticulous work.
ImageEngine 2.jpg by graham.curtis, on Flickr
malcolmgb wrote:I have had my cases vapour blasted here in the UK recently, when I asked about keeping them clean he told me he uses a household furniture polish (silicon type) on his, they clean easily and have lasted some years. That is my plan when I finally rebuild the engine.
