Lights suddenly not working, any ideas?
rider5
Post by rider5 » Sun Apr 07, 2019 1:34 pm
My '67 305 Dream has decided her lights aren't going to work, both the headlight and brake light. Since it's pretty doubtful that both bulbs would fail at the same time I think it's something else. Could it be the rectifier?
Any thoughts or ideas would be greatly appreciated, thanks.
Geoff Hastings
Post by Geoff Hastings » Sun Apr 07, 2019 4:26 pm
Rather than speculate as to wether both bulbs could blow simultaneously why not check them? It won't take a couple of minutes. Might be a current spike because of a bad earth, and they did both blow, or, might be you had not noticed the stop light failed until you noticed the head light go.
DJM
Failed lights
Post by DJM » Sun Apr 07, 2019 5:33 pm
Not likely to be the rectifier.
rider5
Post by rider5 » Sun Apr 07, 2019 6:08 pm
Thanks DJM & Geoff Hastings for responding, I'll check out the bulbs.
rrietman
Post by rrietman » Sun Apr 07, 2019 10:29 pm
does the taillight come on? if so in which switch position?sounds like a switch problem. the soldered connections on the back of the ign switch are prone to failure. study the wiring diagram and do some continuity checks.
Good luck
Randy
