CB77 Charging Output
ramwing7
CB77 charging output
Post by ramwing7 » Tue Apr 25, 2017 9:01 am
I did replace the rectifier with one sourced from Radio Shack. It seems to be working fine.
What problems I'm having seems to be coming from the dimmer switch on the left handlebar.
Nearest I can tell the switch determines which charging circuit you're on.
My switch seems to be making poor contact and I sometimes get wild fluctuations in the voltage being delivered to the battery.
Could be I'm seeing ghosts or looking for something to tinker with. Dunno? : )
BTW. Outstanding job on that Dream.
DJM
Post by DJM » Tue Apr 25, 2017 5:29 pm
It isn't the dimmer switch that controls the charging output but the main lighting switch, on a C or CA model I think this is incorporated in the combination ignition / lighting switch but definitely NOT the dimmer switch.
Post by G-Man » Wed Apr 26, 2017 3:52 am
DJM
Absolutely correct. On some bikes though, the dimmer has a 'dead spot' between Hi and Lo and this can cause confusion.
DJM wrote:It isn't the dimmer switch that controls the charging output but the main lighting switch, on a C or CA model I think this is incorporated in the combination ignition / lighting switch but definitely NOT the dimmer switch.
barnbiketom
Post by barnbiketom » Wed Apr 26, 2017 7:27 am
If you use a cheap meter, you WILL see wild fluctuations if not far as possible from the coils, points, etc. I use 8 foot test leads and place my meter on the floor...It settles down nicely.
I like stock...
A few modern mods...
But worst of all are those gawl dang PODS
ramwing7
Post by ramwing7 » Wed Apr 26, 2017 12:22 pm
Thanks for the clarification. I must be in possession of some of those alternative facts going around. ; )
With these real facts I can now pursue some other directions.
BTW Where do you gEt 8' leads for your meter?
Berkeley Boone
Lighting / Battery Issues
Post by Berkeley Boone » Thu Apr 27, 2017 3:16 pm
In response to the questions regarding the loss of battery power while running the lights... I use a trickle charger every time I park my bike. Further, I have removed my headlight bulb and replaced it with Denali D2 running lights (www.twistedthrottle.com). The bright mode will burn the chrome off the bumper in front of you if you're not careful! They are dual intensity, so can can dim your lights. I also run an LED tail light bulb (superbrightlights.com). This is my set-up but they may or may not work for you...
