1965 CA77 Ignition Switch Internal Contact Position
bjshealy
Post by bjshealy » Mon Oct 25, 2010 4:49 pm
Does anyone have a diagram/photo showing the correct contact position inside the combination/ignition switch?
I was not getting the battery voltage to the starter (ST) but the ignition (IG) did have the 12 volts in the correct key positions. The switch was previously taken apart but appears to be all there. Three springs, 3 ball bearings, 3 insulators, and 3 triangle shaped three-contact terminals. However the 3 three-contact terminals can be installed 180 degrees out, having one contact or two contacts facing out.
A diagram or photo would help very much!!
Thank you.
brewsky
Post by brewsky » Mon Oct 25, 2010 6:22 pm
bjshealy
CA77 Combination Switch Internal Contacts
Post by bjshealy » Tue Oct 26, 2010 7:21 am
Thank you for the response. I have used both diagrams (the switch matrix and the wiring schematic)to troubleshoot the starter electrical problem to the internals of the switch itself. Now I need a photo or a diagram of the internal contact placement position. I have seen one in the past but cannot find it now that I need it!
I will keep you posted.
Many thanks again.
Re: CA77 Combination Switch Internal Contacts
Post by LOUD MOUSE » Tue Oct 26, 2010 7:41 am
TEXAS is a large state.
What part are ya holding down?. .......lm
bjshealy wrote:Thank you for the response. I have used both diagrams (the switch matrix and the wiring schematic)to troubleshoot the starter electrical problem to the internals of the switch itself. Now I need a photo or a diagram of the internal contact placement position. I have seen one in the past but cannot find it now that I need it!
Many thanks again.
bjshealy
Post by bjshealy » Tue Oct 26, 2010 10:15 am
I reside in the Houston area ... La Porte, Texas.
Thanks.
BJS
Post by LOUD MOUSE » Tue Oct 26, 2010 10:55 am
Add that to ya profile?. .....lm
bjshealy wrote:I reside in the Houston area ... La Porte, Texas.
Thanks.
BJS
Post by e3steve » Wed Oct 27, 2010 6:17 am
Many thanks again.
Welcome to The Forum. 5 position or 6 position combination switch?
