High Output Stator Kit
cknight
Post by cknight » Wed Sep 07, 2016 11:19 am
Rick's Motorsport Electrics has issued a blog post, announcing the re-introduction of their 99-102 high output stator and regulator/rectifier kit for the CA/CB/CL 72/77's. I have installed a couple of these on CB77's (not my own bikes, but I will now), and the folks seem pleased with them. A bit of creativity is required to mount the regulator/rectifier, but nothing beyond a bit of common sense. Regards, Chase
Post by Seadog » Wed Sep 07, 2016 12:14 pm
Thanks, nice to know, but it doesn't seem to up on their website yet.
Re: High Output Stator Kit
Post by LOUD MOUSE » Wed Sep 07, 2016 6:49 pm
Any pics of it Chase?. .............lm
cknight wrote:Rick's Motorsport Electrics has issued a blog post, announcing the re-introduction of their 99-102 high output stator and regulator/rectifier kit for the CA/CB/CL 72/77's. I have installed a couple of these on CB77's (not my own bikes, but I will now), and the folks seem pleased with them. A bit of creativity is required to mount the regulator/rectifier, but nothing beyond a bit of common sense. Regards, Chase
cknight
Post by cknight » Thu Sep 08, 2016 9:18 am
Hi LM, they don't seem to have posted any images yet. The two that I had previously received from them were each a bit different. They both had a charging coil wire mount made from injection molded material, pressed into a small metal ring. This then had to be mounted into a stock stator housing that the customer would have to provide. The tricky part is, you will have to remove the stock pointer from your old stator, or fabricate a new one, for the rotor's timing markings. This is attached with each of the stock stator's three adapters for the bolts that attach the round alternator cover, which would also be transferred from your stock stator assembly. The first regulator/rectifier unit had a four wire configuration, two from the stator with bullet connectors, an a positive and negative for the battery with ring terminals. The later version was a five wire configuration with a modular plug connection at the r/r, along with a compatible harness. Bullets again for the stator input, rings for the battery. It also had an additional white wire for switched ignition +. The r/r was about 2-1/4" x 2-3/4", with mounting bolt holes at each end. Not sure if this is what the new release will be, just my previous experience. Regards, Chase
Post by LOUD MOUSE » Thu Sep 22, 2016 8:41 am
Thanks Chase.
Just returned from the RENO AIR RACES. ............................lm
cknight wrote:Hi LM, they don't seem to have posted any images yet. The two that I had previously received from them were each a bit different. They both had a charging coil wire mount made from injection molded material, pressed into a small metal ring. This then had to be mounted into a stock stator housing that the customer would have to provide. The tricky part is, you will have to remove the stock pointer from your old stator, or fabricate a new one, for the rotor's timing markings. This is attached with each of the stock stator's three adapters for the bolts that attach the round alternator cover, which would also be transferred from your stock stator assembly. The first regulator/rectifier unit had a four wire configuration, two from the stator with bullet connectors, an a positive and negative for the battery with ring terminals. The later version was a five wire configuration with a modular plug connection at the r/r, along with a compatible harness. Bullets again for the stator input, rings for the battery. It also had an additional white wire for switched ignition +. The r/r was about 2-1/4" x 2-3/4", with mounting bolt holes at each end. Not sure if this is what the new release will be, just my previous experience. Regards, Chase
cknight
Post by cknight » Thu Sep 22, 2016 9:08 am
Hello LM, hope you had a good time out there. Close call with that feller that had the aborted takeoff. Rick's has posted images now of their 99-101 kit. That's for the 350's and 360's, and looks like the later unit that I had received with the five wire harness and the modular plug. Regards, Chase
cron
