CL77 lower exh pipe
CL77 lower exh pipe
Post by davomoto » Sat Jan 03, 2009 4:56 pm
I am in need of a lower exhaust pipe for a CL77. The upper has the muffler welded on, but I think the lower is the same . Decent condition or better, I really don't need a rusted out one. as I already have one. Will purchase or trade for CB/CL parts. What do you need?
FAST FRED
CL77 PIPE
Post by FAST FRED » Sat Jan 03, 2009 10:42 pm
DAVE, THERE ARE TWO DIFFERENT LOWER PIPES. THE EARLY PIPE HAS FOUR TABS FOR MOUNTING THE HEAT SHIELDS AND THE LATTER PIPE HAS FIVE. IF YOUR UPPER PIPE HAS THE MUFFLER WELDED TO IT ITS THE LATTER PIPE WITH FIVE TABS YOU NEED ALSO, I HEARD SOMEWHERE THE EARY PIPE HAS A SHARPER BEND AND DOES NOT FIT THE LATTER UPPER PIPE.
FAST FRED
65 CL77
66 CL77
76 CB550FKR
76 CT90
Post by davomoto » Mon Jan 05, 2009 2:44 pm
Thanks for the info Fred! I thought the only difference was the heat shield tabs.
Davo
Re: CL77 PIPE
Post by LOUD MOUSE » Mon Jan 05, 2009 7:06 pm
The earlier pipe uses a totaly different rear mount. The early pipes fit to early and the last (late) fit each other but do to the rear mount they don't mix. The CL72 (250) left side pipe does have a bend which starts right at the exhaust exit where the CL77 has apx. 1 1/4 inch out to the bend. .............lm
FAST FRED wrote:DAVE, THERE ARE TWO DIFFERENT LOWER PIPES. THE EARLY PIPE HAS FOUR TABS FOR MOUNTING THE HEAT SHIELDS AND THE LATTER PIPE HAS FIVE. IF YOUR UPPER PIPE HAS THE MUFFLER WELDED TO IT ITS THE LATTER PIPE WITH FIVE TABS YOU NEED ALSO, I HEARD SOMEWHERE THE EARY PIPE HAS A SHARPER BEND AND DOES NOT FIT THE LATTER UPPER PIPE.
FAST FRED
RIDE IT DON'T HIDE IT!
Post by davomoto » Mon Jan 05, 2009 8:38 pm
Ed, thanks once again for your expertise! It is as always, much appreciated!
Davo
