PDO::ERRMODE_EXCEPTION, PDO::MYSQL_ATTR_INIT_COMMAND => "SET NAMES utf8mb4", ] ); // newest completed CA entry (via view) $sql = " SELECT model_year, model, ADM_StateOrProvince, ADM_Country, condition_value, opinion_value_today FROM h305_ca77_entries ORDER BY submitdate DESC, id DESC LIMIT 1 "; $row = $pdo->query($sql)->fetch(PDO::FETCH_ASSOC); // casing helpers (same pattern as CB / CL) $keepCaps = static function (string $w): bool { return (bool)preg_match('/[A-Z]{2,}/', $w) || (bool)preg_match('/\d/', $w); }; $word = static function (?string $w) use ($keepCaps): string { if ($w === null || $w === '') return ''; if (strpos($w, '-') !== false) { $parts = explode('-', $w); foreach ($parts as &$x) { $x = $keepCaps($x) ? $x : ucfirst(strtolower($x)); } return implode('-', $parts); } if ($keepCaps($w)) return $w; $dot = substr($w, -1) === '.'; $base = $dot ? substr($w, 0, -1) : $w; $done = ucfirst(strtolower($base)); return $dot ? ($done . '.') : $done; }; $title = static function (?string $s) use ($word): string { if ($s === null) return ''; $s = trim($s); if ($s === '') return ''; $t = preg_split('/\s+/', $s) ?: []; foreach ($t as &$x) $x = $word($x); return trim(implode(' ', $t), ", "); }; if (!$row) { $line = 'Latest Registry Entry: No completed entries found.'; } else { // location like "WA, Australia" $region = $title($row['ADM_StateOrProvince'] ?? ''); $country = $title($row['ADM_Country'] ?? ''); $loc = trim( implode(', ', array_filter([$region, $country], fn($v) => $v !== '')), ', ' ); // normalize opinion_value_today using the same rules as CL: // - >=1000 => use as-is ($12500 => $12,500) // - 100..999 => treat as dollars ($750 => $750) // - 1..99 => treat as thousands (6 => $6,000) // - otherwise => "Not Entered" $valFinal = 'Not Entered'; if (isset($row['opinion_value_today']) && $row['opinion_value_today'] !== '') { $n = (float)$row['opinion_value_today']; if ($n >= 1000) { $valFinal = '$' . number_format($n, 0); } elseif ($n >= 100) { $valFinal = '$' . number_format($n, 0); } elseif ($n > 0) { $valFinal = '$' . number_format($n * 1000, 0); } } // condition code translation — same dictionary as CL plus "Rat" $condRaw = $row['condition_value'] ?? ''; $condMap = [ 'E' => 'Excellent', 'Exc' => 'Excellent', 'G' => 'Good', 'Goo' => 'Good', 'F' => 'Fair', 'P' => 'Poor', 'Par' => 'Parts Bike', 'R' => 'Restored', 'Res' => 'Restored', 'Rat' => 'Rat', ]; $condNice = $condMap[$condRaw] ?? ($condRaw !== '' ? $condRaw : 'Not Entered'); $line = 'Latest Registry Entry: ' . ($row['model_year'] ?? '') . ' Honda ' . ($row['model'] ?? '') . ' — ' . $loc . ' — Condition: ' . $condNice . ' — Value: ' . $valFinal; } // stamp + UTF-8 $built = (new DateTime('now'))->format('Y-m-d H:i:s T'); $stamp = ""; $charset = ''; $html = $charset . "\n" . $stamp . "\n" . $line . "\n"; // write to shared include $jobDir = __DIR__; $includeDir = '/home/mstoic3/public_html/shared/include'; $includeTmp = $includeDir . '/latest_ca77.tmp'; $includeDst = $includeDir . '/latest_ca77.html'; $jsonPath = $jobDir . '/latest_ca77.json'; $logPath = $jobDir . '/logs/latest_ca77.log'; // future optional if (!is_dir($includeDir)) { if (!mkdir($includeDir, 0755, true) && !is_dir($includeDir)) { throw new RuntimeException("Failed to create include dir: $includeDir"); } } if (file_put_contents($includeTmp, $html, LOCK_EX) === false) { throw new RuntimeException('Failed to write temp include file'); } if (!rename($includeTmp, $includeDst)) { @unlink($includeTmp); throw new RuntimeException('Failed to move include into place'); } @file_put_contents($jsonPath, json_encode([ 'line' => $line, 'stamp' => $built, 'ts' => date('c'), ], JSON_UNESCAPED_UNICODE)); echo "OK\n"; } catch (Throwable $e) { error_log("[generate_latest_ca77.php] " . $e->getMessage()); if (function_exists('http_response_code')) { @http_response_code(500); } echo "ERROR\n"; exit(1); }
Looking for a CA95 front fender and headlight case-FOUND !!
onchiman
Post by onchiman » Thu Nov 19, 2009 6:15 pm
Hi all. I recently picked up a very nice 1965 CA95 150cc. It needs a front fender and headlight/speedometer case (the piece that holds the headlight, speedometer, ignition switch etc.). I'm looking for scarlet colored parts in good condition. Although to me the Honda "scarlet" looks more on the orange side but anyway....I digress. Please let me know. Thanks
1963 Dream 305
mattc
Re: CA95 front fender
Post by mattc » Tue Nov 24, 2009 4:05 pm
Greetings, I have a NOS,OEM front fender for a CA95. It is Honda grey primer. I paid $190.00 for it because they are almost impossible to find with the correct flair at the bottom, as most were severely dented then fixed. I will sell it for what I paid for it. Thanks, Matt
onchiman
Post by onchiman » Fri Nov 27, 2009 8:48 am
Thank you for the offer.
1963 Dream 305
kwbayer
Post by kwbayer » Wed Dec 02, 2009 8:17 am
I have a original ca95 front fender i actually have an entire bike still together want the hole thing?
onchiman
Post by onchiman » Wed Dec 02, 2009 10:24 am
Thanks for the offer but I purchased a fender and speedometer case just a day ago.
1963 Dream 305
Post by davomoto » Wed Dec 02, 2009 2:53 pm
Plese delete your ad if you've found the part!
onchiman
Post by onchiman » Wed Dec 02, 2009 5:55 pm
I tried to delete it but it won't give me the option.
1963 Dream 305
Return to “Wanted - Parts | Bikes | Services”
