I'm looking for a CL72, or 65 CL77 swingarm. It is for the early single leading shoe small hub, and needs to be for clevis mount shocks. I have a couple of the earlier ones that use eye to eye shocks, and a couple later for the large hub that use eye to clevis shocks. Will trade or purchase, let me know what you need. Also need a tool box for CL72 / 77
Davo
CL72 swingarm
CL72 swingarm
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
66 CL77 big bore flat tracker
Many others!
64 CB77
63-7 CB77 Cafe'
67 CL77
64 CL72
Many others!
Davo,
I've got your 65 swingarm and Tool Box.
I can use the Eye to Eye swingarm and go straight up trade if you want. I bet it don't still have the japanese sticker on it. FWIW I bought a 63' 250 parts bike last month from a guy in Kentucky. When I got there to pick it up I noticed another scrambler sitting in the back of the shop. Someone had taken the rear wheel, swingarm(with the sticker), a flawless early seat, the pipes, and a "perfect" set of alloy fenders with the correct front stay off of the bike that I was buying and put all this stuff on a late model 305 with a bad engine. Guess they figgered the 305 would be worth a lot more when they got it "fixed up".
Just to verify that I get the right part, the biggest difference that I see is the casting on the early swingarm, with the clevis, is a socket to the tube where the large hub casting kinda forks over the tube where it is welded. I've got both styles loose right now and a couple of small hub swingarms still mounted on rollers.
Let me know,
Mark
Let me know,
Mark
