Connecting rods
Jefft
Connecting rods
Post by Jefft » Wed Nov 21, 2018 7:07 pm
I’m in the process restoring a couple of CB77 and need a couple of decent connecting rods to work with. I’m prepared to modify them to use oversize pins but I want to start with the best pieces I can find.( no rust and salvageable.) let me know what you have. Any help would be greatly appreciated.
Re: Connecting rods
Post by G-Man » Thu Nov 22, 2018 2:51 am
Jefft
They come up on eBay occasionally. I am rebuilding many CB/CL/CA77 and found two sets in a box of rusty parts recently in a barn full of parts in UK.
I don't know if I'll have any spares for the forseeable future but, if you are patient, you'll find something.
These rods were re-claimed in my workshop by bushing the small-ends.
Jefft wrote:I’m in the process restoring a couple of CB77 and need a couple of decent connecting rods to work with. I’m prepared to modify them to use oversize pins but I want to start with the best pieces I can find.( no rust and salvageable.) let me know what you have. Any help would be greatly appreciated.
Post by Seadog » Thu Nov 22, 2018 9:38 am
I wonder if it’s possible to convert the con rod ends to use needle bearings? Is there enough material?
Jefft
Post by Jefft » Thu Nov 22, 2018 9:50 am
How thick will your small end bush be? The small ends are not very big so there is not a lot of material to work with. Let me know what your plan is and I may bush mine.
Post by Seadog » Thu Nov 22, 2018 9:58 am
Jefft wrote:How thick will your small end bush be? The small ends are not very big so there is not a lot of material to work with. Let me know what your plan is and I may bush mine.
I'm just being curious, Jeff. I don't have the facilities to machine for bushings or bearings.
Post by G-Man » Thu Nov 22, 2018 1:01 pm
Not really enough room and not often done in four strokes because of the high loads.
Seadog wrote:I wonder if it’s possible to convert the con rod ends to use needle bearings? Is there enough material?
Post by G-Man » Thu Nov 22, 2018 1:02 pm
Bushes are 0.5 mm wall thickness when finished. I make a thick bush, press it in then finish bore in situ.
