CB77 std piston rings
Re: cb77 0.50 piston pics
Bore to at least 3rd.
New pistons and rings. ................lm
Merz64cb77 wrote:here are some pictures of the 0.50 piston, rings and cylinder bores. One cylinder and piston is worse than the other. would you recommend that I hone the rust off and re-use the existing pistons and just purchase new 0.50 rings or overbore to a 3rd or 4th and buy all new from Tim at Classic honda restoration
Merz64cb77
Can I re use my piston pins and clips with 3rd or 4th over pistons?
Re: CB77 std piston rings
You can use the clips unless you destroy them.
If you can feel/see a difference in diameter at the rod location you may want to replace them.
Also check the rod ends for wear/grooves. ..............lm
Merz64cb77 wrote:Can I re use my piston pins and clips with 3rd or 4th over pistons?
Merz64cb77
Ok will do thanks for the info and advice LM.
Merz64cb77
Hi randy
What is involved in completing a proper valve job?
