Wanted: CL72 clutch/brake lever perches (brackets)
I am looking for a set of used CL72 clutch & front brake lever brackets, with or without levers. These are the early type with the stopper wire, and they require cables with large knurled adjuster nuts. TIA --Randall
Re: Wanted: CL72 clutch/brake lever perches (brackets)
I have some. I'm working on the fender. SLOW. ..............lm
rbaselt wrote:I am looking for a set of used CL72 clutch & front brake lever brackets, with or without levers. These are the early type with the stopper wire, and they require cables with large knurled adjuster nuts. TIA --Randall
