looking for a a couple of things
AWILLIAMS64
Post by AWILLIAMS64 » Sat Aug 09, 2008 1:16 am
i have a 65 superhawk and need a key. ignition switch has VA626 stamped on it. also need a place to buy the boots that go from the airbox to each carb., Mine are in pretty bad shape. also will eventually will need kickstarter, the gear is there but nothing else, and a headlight glass.
Post by davomoto » Sat Aug 09, 2008 10:23 pm
Key is most likely NA626, not VA. Try Hondakeys.com. Clauss studios has repro air tubes, reasonable price. http://claussstudios.com/ . Ebay, western hills honda, or Ohio cycles for other parts. Here's another good link. http://www.olypen.com/retro/
AWILLIAMS64
Post by AWILLIAMS64 » Sat Aug 09, 2008 10:42 pm
you are right, the key is a na626, on the switch it looks like the "N" did not get fully stamped, it definitely looks like a slanted V, but on the fork lock it definitely has NA626. Since i am in ohio i may have to check out the ohio cycles place. i put out a request to hondakeys, now i will have to go back and send another request w/ the tight #. I really appreciate you letting me know i had the wrong #. I have never had a chance to do any "restorations" on any vehicle so this is my first one. I think half of the fun is reading all the info. I would say the biggest rush is when i hit the starter button and it actually started! its weird, just as i was posting this Mark from hondakeys.com emailed me saying it was a wrong #!
my first decent picture of my project. The hoses around the bars are the gas lines that i ran just to get it started.
AWILLIAMS64
Post by AWILLIAMS64 » Sat Aug 09, 2008 10:55 pm
so if i can find someone who has a key should it say na626 on the key? or would it have to be cut to match my locks?
Post by LOUD MOUSE » Sun Aug 10, 2008 7:24 am
I have keys with that number on them. ....................lm
AWILLIAMS64 wrote:so if i can find someone who has a key should it say na626 on the key? or would it have to be cut to match my locks?
RIDE IT DON'T HIDE IT!
AWILLIAMS64
Post by AWILLIAMS64 » Sun Aug 10, 2008 9:36 am
could you give me a price on them. would they have to be cut or are they already ready to use in my locks?
1965 superhawk...project
AWILLIAMS64
Post by AWILLIAMS64 » Fri Aug 15, 2008 1:54 am
i was able to get a couple of keys for my switch today at the local locksmith. He charged $22 for the first one and then $3.50 for each additional. Thanks lm for the option to get one from you it would have been great if this had not worked out.
would this be the headlight replacement i would need? http://cgi.ebay.com/ebaymotors/Honda-CB ... 8783338175
the pic is what i currently have, or dont have depends on how you look at it.
