CL77 Speedo Mount
conbs
CL77 Speedo Mount
Post by conbs » Sat Jun 13, 2009 4:28 pm
I will need the rubber speedo mount for my bike. I am just getting started on it and have lots of time, but in all my e-bay shopping in the last year or so I have only seen one that even looked usable. Most are either missing or unusable.
Has anyone remanufactured this part? I haven't seen any on the vendor websites I have visited.
I have the metal rings that the rubber sits in. Will I have to cast the new rubber for it myself?
rgtaylor2
Post by rgtaylor2 » Mon Jun 15, 2009 10:57 am
I have only seen a couple on eBay and they went for big bucks. If you can make your own it would probably do your wallet a favor, should be pretty easy if you have foam stock.
65 CA77 Dream
66 CL77 Scrambler
69 Triumph TR6
conbs
Post by conbs » Wed Jun 17, 2009 10:00 am
RG
I was actually thinking of making a mold using the remnants of the old mount for dimensions and then using Flexane rubber to make a new one.
Have you made one out of foam? If so, what kind of foam did you use and how did you shape it?
rgtaylor2
Post by rgtaylor2 » Wed Jun 17, 2009 12:45 pm
I have never tried to make one but I think you could use a piece of rubber mat about 1/2 thick, a really good exacto knife to trim and then seal it all with silicone. Let us know what you use and the results.
65 CA77 Dream
66 CL77 Scrambler
69 Triumph TR6
DONZIE
Post by DONZIE » Wed Jun 17, 2009 9:42 pm
I have a few nos ones & when I do sell they go for $75 -$100
If you have the metal piece in good condition make a trip to a hardware store & get a roll of stiff foam weather stripping about 1/2" by 1/2" square with the adhesive on it. Wrap it around the speedo & carve off excess with a single edge razor blade and sandpaper. Done right impossible to tell differance from oem honda once installed if you hide the seam to the backside.
conbs
Post by conbs » Fri Jun 19, 2009 11:28 am
Thanks for the help. I am going to experiment with your ideas and see what I come up with. If anyone else has experience or ideas I would appreciate about them as well.
