Ignition switch nut, and front fork bolt needed
advantagecycle
Post by advantagecycle » Sat May 29, 2010 9:22 pm
I wanted to see if anyone has the shiny outer nut for an OE honda ign switch? I have a good switch, and found keys for it, but the nut crumbled when I went to take it off.
I also need the 12mm bolt the holds the front scisior at the bottom of the fork leg.
advantagecycle@aol.com
Paul
FAST FRED
What is it?
Post by FAST FRED » Sat May 29, 2010 9:58 pm
Paul, what model of honda do you need these parts for?
fast fred
65 CL77
66 CL77
76 CB550FKR
76 CT90
advantagecycle
Post by advantagecycle » Sat Jun 05, 2010 5:04 pm
Oops, it is a CA77.
I ended up buying a whole switch on ebay for the nut, and found a couple bolts at napa that worked well.
Paul
