ca77 clutch plates
kirbb9
ca77 clutch plates
Post by kirbb9 » Mon Jul 12, 2010 10:41 pm
Looking for friction plates for a 66 dream. This one has 5 plates and two wire rings.
Thanks, Brady
kirbb9
Post by kirbb9 » Wed Jul 14, 2010 6:18 pm
Just found a set. Ohio Cycles has them for 10 bucks ea. $50.00 plus $7.50 shipping.
Brady
brewsky
Post by brewsky » Wed Jul 14, 2010 6:41 pm
Would love to know how they work out.
The only oem plates I could find were about $30 each. I assume they were the fiber/metal version.
I did find some all fiber aftermarket online somewhere for a lot less.
There were probably 3 or more versions of the clutch with different thickness plates and different springs.
If you do a search you can find several threads on the subject.
My '66 had all fibers which were slipping (not from wear since they were way thicker than the specs call for).
I ended up with some used re-furbished fiber/metal versions and different springs from LM and they work fine.
teazer
Post by teazer » Wed Jul 14, 2010 10:24 pm
I'm going to have to dig through all my old notes. many years ago i researched what alternate plates were available for my race bike and I ended up with a pack of 7 plates in place of the stock 5 and zero clucth slip on a tuned motor.
Not that anyone else needs more plates. The point is that there were other plates available that worked equally well that may be more affordable.
Someone probably has a listing tucked away somewhere that is more up to date than my old notes.
joeweir1
Post by joeweir1 » Thu Jul 15, 2010 2:40 pm
You probably are getting the all fiber plates for that price.
kirbb9
Post by kirbb9 » Sun Jul 18, 2010 1:24 am
Brewsky, that was my issue also. The 5 plates are thicker than the manual says they should be.
As soon as I can I will get back to you and let you know how they work.
Ohio Cycle is a mail order only business so I am waiting for the mailman!!
Brady
kirbb9
Post by kirbb9 » Fri Jul 23, 2010 2:21 am
Mailman came today! The plates are all fiber. I threw them is a pan of oil for 5 minutes and put them in. Had to
turn the right side adjustment in a bit to remove slack from the cable and did a test ride. Everything seems to be
working properly. Will holler back if any issues arise.
Nick at Ohio Cycles was excellent to work with, Quick shipping and no hassles.
Brady
