                    Help with Serial Numbers
I just bought a 305 scrambler. The bike is titled as a 66 and has frame CL771032393 and engine CL77E1021028.
						Both bikes are non matching numbers.  305s usually run much closer but rarely a true match.  My 66 CL77 has only one number difference and I believe that's unusually close.  I believe 30-50 is common and some have said there could be as many as a couple of hundred.  Both your frames are significantly newer than their engines.  But then, who cares?  You've got two CL77s, what could be better?  I purchased a CL350K1 at Mid Ohio last year.  It was represented as an original survivor but there are about 3,500 numbers between the engine and frame.  Post some pictures of your scramblers.
