The Neverending Tale of a '65 Superhawk Restoration
cfloren
Post by cfloren » Thu Oct 29, 2009 10:17 pm
Now it's wheel time. My old wheels were mismatched, bent, rusty and ugly. The front was an aluminum shouldered rim, of unknown brand. It was the bent rim that caused my front tire blowout, mentioned at the beginning of my restoration thread. The rear was one of the original chromed steel rims. The hubs showed the usual oxidation and staining. I found a few bent spokes but mostly they were just rusty.
As removed from the bike:
Front aluminum rim:
Front hub:
Rear hub:
I cut the old spokes out but saved an inner and outer from each wheel for reference. I cleaned the hubs thoroughly, then had a go at polishing them myself. The thing was, my cheap Harbor Fright (sic) buffing wheel leaves a lot to be desired in the power department. I couldn't apply enough pressure for long enough to get a good shine. Knowing that polishing labor is cheap, I decided to leave this job to the pros and dropped them off at a local shop, along with the brake backing plates.
The spokes went out to Buchanan's Spoke & Rim as examples for new stainless steel parts. I ordered my rims through them too. I settled on the Excel shouldered aluminum, WM2 (1.85) x 18" for the front and WM3 (2.15) x 18" for the rear. Originally I was going to lace them up and call the wheels done, but then something possessed me to have the rims polished and anodized black. I really dig the results.
Spokes identified and ready to go meet the spoke meisters:
New stainless spokes laced to new Excel rims, hubs are shown after my mediocre polishing attempt:
And finally, polished hubs + stainless spokes + stainless nipples + polished & black anodized rims =
Lacing was not so bad. It was tricky to get all the spokes in without scratching the rims, but I'm sure I didn't use the easiest method. I just looked at my photos of the old wheels and duplicated the pattern.
I recently trued them up myself, down to under 0.010" of runout both axially and radially.
And last night I finished mounting the tires.
More photos to come.
block
Post by block » Fri Oct 30, 2009 1:14 am
Those wheels are beautiful! Good show sir.
Post by davomoto » Fri Oct 30, 2009 2:53 pm
Those wheel are sick! Nicely done. I built the exact same set-up for deez cafe bike, without the anodizing. Can't wait to see them on the bike!
cfloren
Post by cfloren » Fri Oct 30, 2009 3:37 pm
Thanks for the compliments. Wheels are a huge part of a bike's visual impact so I wanted to make them look as good as possible. And as you can see, although this bike is getting a full rebuild and restoration, it won't be 100% showroom stock.
I may even get the "Takasago EXCEL Rim" stickers in yellow text for the rims, to give them a finishing touch. The anodizing is really beautiful and easy to clean, but the downside is that it's easy to scratch through to bare aluminum underneath with a steel spoke wrench or tire iron (don't ask how I know).
Post by davomoto » Fri Oct 30, 2009 5:14 pm
I've done several sets of anodized black supermoto wheels, and it's stressful making sure not to scratch someones new jewelry! I tape the crap out of the spoke wrench, and flat out refuse to mount the tires. Some shrinK wrap melted on tire irons is a good simple protection.
Mike Mullins
re:
Post by Mike Mullins » Fri Oct 30, 2009 5:31 pm
Chris: you are giving me ideas for Bob the Bobber that my wife will tell me I cant afford. VERY NICE !
Mike
66 CB 77
76 BMW R75/6
99 GL 1500 trike
75 & 79 XS 650's
Superchicken
Post by Superchicken » Fri Oct 30, 2009 6:10 pm
this guy, pulls the beads together tight, then slips, tire, on. No tool
